As some of you know, I have finally suceeded in building a guitar effects box, thanks to all the help I received here ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This is the schematic I used. https://www.electronicspoint.com/forums/attachments/screen-shot-2020-06-22-at-10-21-12-pm-jpg.48602/
I am now in the process of putting it into a box. let me explain though.
At this point, I just want to build a few of these circuits, experimenting with different op amps, sound etc. So, I am not going to put a regular stomp box switch in these boxes. The reason for this is two fold:
1. I found some perfectly sized wooded boxes at the dollar store, that I will repurpose for use as the stomp box housing. As such, I don't want a switch that you have to stomp on, because the box won't be able to withstand it.
2. I'm just using a cheap on/off switch for now.
Here is my question:
Using the above circuit, can I add a red LED that will light to signify that the box is active (actually producing distortion), and is not lit when it is off?
I plan on using a simply switch that I will mount on the front or side of the box. I'd like it to work so that it kills the connection to the 9 Volt battery when not in use, and lights up the LED and sends power to the necessary parts of the circuit when in use. In that way, it will also serve to save the battery when not in use.
Can anyone suggest an addition to the schematic that will do that?
Thank-you
Thank-you
