LCD TV repair help! Please
LCD TV Philips 30PF9946/12
Powers on and works fine apart from the picture is dark in places, almost 3/4 of the sceen is dark but full picture still visible.
Inverter board DARFON V144 48.V1448.021 / A Model V144-301
Found a blown component A36AK FDS 6956A
Not found out much other than it appears to be a Dual N-Channel Logic Level PowerTrench MOSFET and although I can find spec sheets for others i.e. FDS6930A,6961A and 6990A I cannot find a spec sheet for this specific part.
Most of the ratings appear to be the same for the FDS69##A range so should I just try one and see or is there something particularly specific for its application on an inverter board?
Thank-you, help appreciated!
