Hi all,
I am trying to repair a 19" Samsung 191T monitor that appears to have
been damaged due to a storm-related power surge over the weekend.
The problem with the monitor is clearly related to the backlight: the
four backlight lamps appear "burnt" and if I shine a bright light into
the back of the panel, the image on the screen appears perfectly fine
The monitor includes two main circuit boards: a big one that the DVI
input and power connects to, and a smaller LCD inverter board. The LCD
inverter board is an Ambit BN44-00060A, which appears nearly identical
to this one: http://www.lcdpart.com/images/AMBIT_K021036.gif
There are no fuses on either board, as far as I can tell.
The LCD inverter board is connected to the main circuit board via a
12-pin connector. The voltages output by the LCD inverter board are
very close to zero, so obviously something is wrong with it :-( If I
understand correctly, the cold cathode backlight bulbs need something
like 1000V AC, is that right?
I would like to be able to verify that nothing is wrong with the power
supply part of the MAIN circuit board as well... does anyone know what
the voltages should be on the 12 input pins to the inverter board?
Since the image is apparently fine, there is no problem with the
display electronics on the main board, but there could be a problem
with the power supply on the main board... I would like to know if
there is a way to tell this.
Can anyone give me any advice on how to test the LCD inverter and main
power supply boards? There are no fuses. Thanks for any advice!!!
Dan Lenski
Dan Lenski
