I have had time to look overthings again.
I made one mistake hooking op the LCD (took the schematics from a different
type with VCC and VDD reversed).
Now I took another Display (DEM16216 SYH-PY-12/V) to make sure I didn't blew
the old one.
Still nothing happens.
I have hooked op all 8 datalines directly to the PIC (Port C) and the RS, RW
and E lines also directly (to Port A)
So now pull-ups and pull-downs and no other peripheral connected.
I've included the code.
Hope someone can help me.
Alexander
; Fosc = 4MHz
; Cycle_time = 1/Fosc / 4
; = 1/(4*10^6) / 4
; = 1uSec
LIST P=18F442, F=INHX8M
include <p18f442.inc>
RESET_V EQU 0x0000 ; Address of RESET Vector
ISR_V EQU 0x0004 ; Address of Interrupt
Vector
OSC_FREQ EQU D'4000000' ; Oscillator Frequency is 4
MHz
LCD_DATA EQU PORTC ; LCD data lines interface
LCD_DATA_TRIS EQU TRISC
LCD_CTRL EQU PORTA ; LCD control lines
interface
LCD_CTRL_TRIS EQU TRISA ; LCD control lines
interface
LCD_LINE0 EQU 0x000
LCD_LINE1 EQU 0x040
; PORTA bits
LCD_E EQU 2 ; LCD Enable control line
LCD_RW EQU 1 ; LCD Read/Write control line
LCD_RS EQU 0 ; LCD Register-Select control
line
; misc.
LCD_TEMP EQU 0x020 ; LCD subroutines internal
use
COUNT EQU 0x022 ; A counter
DELAY equ 0x023 ; Used in DELAYxxx routines
X_DELAY equ 0x024 ; Used in X_DELAYxxx
routines
; Program start
ORG RESET_V ; RESET vector location
GOTO START
; This is the Interrupt routine. Should NOT get here
ORG ISR_V ; Interrupt vector location
INTERRUPT:
RETFIE
GOTO INTERRUPT
; Initialize processor registers
START: ; POWER_ON Reset (Beginning of
program)
MOVLW 0x07
MOVWF ADCON1
CLRF TRISA
MAIN:
CLRF LCD_DATA ; ALL PORT output should
output Low.
CLRF LCD_CTRL
MOVLW 0x000 ; RB7-0 outputs
MOVWF LCD_DATA_TRIS
CALL LCDINIT ; Initialize LCDisplay
CALL LCDHOME
MOVLW 0x030 ; ASCII '0'
CALL LCDPUTCHAR ;
MOVLW 0x031 ;
CALL LCDPUTCHAR ;
MOVLW 0x032 ;
CALL LCDPUTCHAR ;
MOVLW 0x033 ;
CALL LCDPUTCHAR ;
MOVLW 0x034 ;
CALL LCDPUTCHAR ;
; Program ends here
LOOP:
GOTO LOOP ; Stay here forever
; LCD Module Subroutines
; LCDINIT
; Initilize LC-Display Module
LCDINIT:
; Busy-flag is not yet valid
CLRF LCD_CTRL ; ALL PORT output should output Low.
; power-up delay
MOVLW 0x03c
CALL X_DELAY500 ; 30 * 0.5mS = 15mS
; Function Set
BCF LCD_CTRL, LCD_RW; Set LCD in read mode
BCF LCD_CTRL, LCD_RS; Set LCD in command mode
BSF LCD_CTRL, LCD_E ; LCD E-line High
MOVLW 0x3c
MOVWF LCD_DATA ; Send data to LCD
BCF LCD_CTRL, LCD_E ; LCD E-line Low
CALL DELAY500 ; 0.5mS
; Display on/off ctrl
MOVLW 0x0c
; Display clear
MOVLW 0x01
MOVLW 0x004
CALL X_DELAY500 ; 4 * 0.5mS = 20mS
; Entry mode
MOVLW 0x06
RETURN
; LCD_ENABLE
; Pulses LCD enable pin
LCD_ENABLE:
RETURN
; LCDBUSY
; Returns when LCD busy-flag is inactive
LCDBUSY:
MOVLW 0x0FF ; Set PORTB for input
MOVWF LCD_DATA_TRIS
BCF LCD_CTRL, LCD_RS; Set LCD for command mode
BSF LCD_CTRL, LCD_RW; Setup to read busy flag
MOVF LCD_DATA, W ; Read busy flag + DDram address
ANDLW 0x80 ; Check Busy flag, High = Busy
BTFSS STATUS, Z
GOTO LCDBUSY
LCDNOTBUSY:
CLRF LCD_DATA_TRIS ; Set PORTB for output
RETURN
; LCDCLEAR
; Clears display and returns cursor to home position (upper-left corner).
LCDCLEAR:
MOVLW 0x001
CALL LCDPUTCMD
RETURN
; LCDHOME
; Returns cursor to home position.
; Returns display to original position (when shifted).
LCDHOME:
MOVLW 0x002
CALL LCDPUTCMD
RETURN
; LCDEMODE
; Sets entry mode of display.
; Required entry mode must be set in W
; b0 : 0 = no display shift 1 = display shift
; b1 : 0 = auto-decrement 1 = auto-increment
; b2-7 : don't care
LCDEMODE:
ANDLW 0x003 ; Strip upper bits
IORLW 0x004 ; entry mode
CALL LCDPUTCMD
RETURN
; LCDDMODE
; Sets display control.
; Required display mode must be set in W
; b0 : 0 = cursor blink off 1 = cursor blink on
; b1 : 0 = cursor off 1 = cursor on
; b2 : 0 = display off 1 = display on (display data remains in DDRAM)
; b3-7 : don't care
LCDDMODE:
ANDLW 0x007 ; Strip upper bits
IORLW 0x008 ; Display on/off control
CALL LCDPUTCMD
RETURN
; LCDSCGA
; Sets Character-Generator-RAM address. CGRAM is read/written after
; this setting.
; Required CGRAM address must be set in W
; b0-5 : required CGRAM address
; b6-7 : don't care
LCDSCGA:
ANDLW 0x03F ; Strip upper bits
IORLW 0x040 ; Function set
CALL LCDPUTCMD
RETURN
; LCDSDDA
; Sets the Display-Data-RAM address. DDRAM data is read/written after
; this setting.
; Required DDRAM address must be set in W
; b0-6 : required DDRAM address
; b7 : don't care
LCDSDDA:
ANDLW 0x07F
IORLW 0x080 ; Function set
CALL LCDPUTCMD
RETURN
; LCDPUTCHAR
; Sends character to LCD
; Required character must be in W
LCDPUTCHAR
MOVWF LCD_TEMP ; Character to be sent is in W
CALL LCDBUSY ; Wait for LCD to be ready
BSF LCD_CTRL, LCD_RS; Set LCD in data mode
MOVF LCD_TEMP, W
RETURN
; LCDPUTCMD
; Sends command to LCD
; Required command must be in W
LCDPUTCMD
MOVWF LCD_TEMP ; Command to be sent is in W
MOVF LCD_TEMP, W
RETURN
; Delay_time = ((DELAY_value * 3) + 4) * Cycle_time
; DELAY_value = (Delay_time - (4 * Cycle_time)) / (3 * Cycle_time)
; i.e. (@ 4MHz crystal)
; Delay_time = ((32 * 3) + 4) * 1uSec
; = 100uSec
; DELAY_value = (500uSec - 4) / 3
; = 165.33
; = 165
DELAY500
MOVLW D'165' ; +1 1 cycle
MOVWF DELAY ; +2 1 cycle
DELAY500_LOOP
DECFSZ DELAY, F ; step 1 1 cycle
GOTO DELAY500_LOOP ; step 2 2 cycles
RETURN ; +3 2 cycles
X_DELAY500 MOVWF X_DELAY ; +1 1 cycle
X_DELAY500_LOOP
CALL DELAY500 ; step1 wait 500uSec
DECFSZ X_DELAY, F ; step2 1 cycle
GOTO X_DELAY500_LOOP ; step3 2 cycles
RETURN ; +2 2 cycles
END ; End of program
