LCD computer display backlighting
Tom Hotaling
I have a Dell LCD monitor where the back lighting has quit. With the
right lighting I can still make out the screen so the digital display
seems fine, just no back lighting.
Any one have any experience with one of these, Dell specific or
generic. I looked through the SamG faq's but nothing jumped out at me.
tomh
Jerry G.
Dell normaly does not sell service parts to no authorised service reps
for their products. There are no published service manuals for these
monitors that are able to be purchased by their non authorized service
reps.
Common causes are the back plane lamps, and their ballast supply. It is
recomended practice to change the lamps and ballast at the same time.
If you call Dell they will tell you where to send the monitor for
proper service. Most of these monitors are sold with a three year
pro-rated warranty. You should enquire about this.
There are no generic parts that I know of.
Some of the lower end monitors have the back light system built in to
the display, and are not serviceable. In this case the complete panel
has to be replaced.
We found that in most cases, when there were failures in these monitors
when out of warranty, it was more feasible to replace the monitor.
Jerry G.
Arfa Daily
Tom Hotaling said:
I have a Dell LCD monitor where the back lighting has quit. With the right
lighting I can still make out the screen so the digital display seems
Any one have any experience with one of these, Dell specific or generic. I
looked through the SamG faq's but nothing jumped out at me. Thanks
tomh
Surface mount fuses ( often 2A ) fail on inverter boards for no good reason.
Driver chips and drive transistors fail. CCFLs fail, though usually just
one, but some inverters will shut down with one tube failed. Tubes are
available on the net, as are inverter boards, but original problem can often
be fixed. Look for the fuse first. You might strike lucky.
Arfa
Jim Land
reason. Driver chips and drive transistors fail. CCFLs fail, though
usually just one, but some inverters will shut down with one tube
failed. Tubes are available on the net, as are inverter boards, but
original problem can often be fixed. Look for the fuse first. You
might strike lucky.
If it turns out you need to replace the lamps and/or the inverter, look
here for DIY info:
http://www.inventgeek.com/Projects/shorts/lcdfix.aspx
http://www.lcdpart.com
There are also companies that will replace the parts for you, such as:
http://laptops.home.att.net/
(Disclaimer: I haven't done business with any of these companies.)
tomh
Thanks all for the tips/advice. This was a freebe I got from a friend
and it's old enough to be out of warranty. I got it to tinker with. I'll
look for blown fuses and bad drivers, etc, and it's definitely a back
lights separate from the screen. To do any serious troubleshooting I'll
need to lengthen the wires from the PCB to the lights. There on a real
short leash. I'll keep y'all posted as to what I find. I suspect a lot
of LCD's hit the trash due to failed back lighting.
tomh
