Hi everybody.
My current application is as follows:
A 12V linear actuator is being controlled by either a programmable timer or a photocell. Power source is a 12V, 6A power supply.
A dpdt relay changes the direction of the actuator motor.
When the programmable timer switches to "on" the actuator extends. When the timer turns "off" the actuator retracts.
Same when using the photocell.
So when the timer /photocell switches "on" the relay/coil is powered the entire time the timer/photocell is in "on" mode which can be between 8-14 hours.
In some cases it would be extremely helpful if no power is consumed once the actuator reached its internal limit switch.
A latching relay comes to mind.
What latching relay would I need and how do I wire it? I guess I would still need a dpdt relay.
I found several latching relays on ebay but not really sure which one I would need and how to wire it to get the same results as in
my current setup.
Thanks a lot for your help!
Wiggi
my current setup.
Wiggi
