I am trying to make a fan using a stepper motor where the radius of the
rotor is very large, say, 1 meter, and the drive is applied at the
periphery of the fan (the fan will have a rim at the outer
circumference).
I want super high rotational speed. The faster the better. Natuarlly
the atmospheric drag will increase with the rotational velocity, but I
was hoping that I could simply increase the speed by increasing the
power delivered.
I can drive the stators in any sequence at any rate with any amount of
current under software control (USB).
Is there a speed beyond which there is a fundamental limitation on how
fast I can pulse my stators? Can I expect to be able to get the fan to
turn faster simply by increasing power? What type of efficiency can I
expect (electrical power to frictional atmospheric forces?) I am
assuming that efficency losses will be in joule heating and radiation,
so it seems that I should be able to get high efficiency. And finally,
a big one, what is the optimum geometry of the magnetic assembly at the
perimeter? How many magnets should I use? Is more really better?
Should I use some sort of super cap array to deliver the pulses? What
types of (electro) magnets should I use? Will I have to worry about
vibration? Lubrication? Metal bearings for direct contact? d-phi-b-dt
effects?
I know I am asking a lot, and I don't need all the answers now, just
some hints to keep me from trying all the silly things.
-Chaud Lapin-
circumference).
power delivered.
effects?
-Chaud Lapin-
