Sir Johnspace. . . . . . .
Why 'soitanly . . . . firstly you digs into your tall stack of money and pulls out your £0.261 and order one of these SEALED tactile switches .
I am including this supplier since I know that they serve your country . . . .WELL.
( Even though, their interplanetary home base is 35 clicks from my front door. . . . I call them "The Mouse House."
http://www.mouser.co.uk/ProductDetail/CK-Components/KSC1001G-LFS/?qs=/ha2pyFaduhfjT3CVoZVRmvJhKMZzrp5c9zqJ6Dn%2bcbKqNOgzp4Kfw==
(Now don't get GREEDY, as they are then only going to have 964 of then left, after filling your order.)
And then YOU build a MINI housing from 4 pieces of acrylic plastic to surround it.( Ever make any plastic models when a kid ?)
That will then create a "bump out" housing to surround the unit for physical protection.
Then you figure out who of your immediate family, happens to know a college or trades instructor . . .or a student who has received training . ..or an electronics "nerd" or an amateur radio operator (HAM).
SOMEONE out of all of that mentioned group, should confirm themselves as being adept at soldering, so have that lucky person take two fine stranded wires and solder one to each of the two contacts on the back of that tactile switch. (THEY are going to have the wire.)
Then, one of the loose wire ends gets soldered to one of the contact pads on the ribbon cable ** and the other free wire gets soldered to the other contact pad on the ribbon cable.
** Fortunately, you have ALREADY found the two "magic" contacts involved, so we won't have to tell you how to trace them down from that old PCB.
The ribbon cable:
Most of the ones I have see have either copper contact tabs or more likely TINNED copper tabs, and will accept a FAST soldering to them.
OR an eraser cleaning of a contact tab and a degreasing of any residue and an immediate drop of applied rosin soldering fliuid will make EXTREMELY quick and easy soldering job for each contact.
If perchance the wire to ribbon cable solder connection is problematic, inquire and I can give you a do it yourself connecting interface solution using:
After connector interfacing is made, press to test the new tactile push button and confirm sweet success.
FIO . . . the tactile switch handles almost NO power at ALL , the real POWER handling is done inside of the laptop, responding to a feeble electrical summons from that tact switch.
Then the connection areas are taped up flat and compact and the cable is inserted back into the case hole, wire slack taken up.
Then the internal rims of the plastic "bump out" receives a toothpick applied seam of Silicone Rubber and is pressed to the pre-degreased area of the case and tape or twine bound to maintain pressure for an overnight cure time.
This creates HOLD, yet it permits removal for any future access needs.
That's the rest of the story . . .now, what say ye ?
73's de Edd
