Kodak 850H Slide Projector Problem
My Kodak 850H Slide Projector is malfunctioning. When I turn it on it begins cycling as if the forward button were being pushed and doesn't stop. Any ideas on what the problem could be?
Could the button be stuck? even if the button isn't, the switch it actuates may be.
Thanks for the reply. When I hit the forward button I can tell it registers, so assume it's not the button itself. I you might be right about the switch that the button engages. I took off the cover and the insides were more complex then I hoped. What to do...
I am trying to repair a Kodak 850h. Does anyone know of a source for the service manual?
Doug
Sir Doug Dunlap . . . . .
INFO is just below . . .what is YOUR units specific problem ?
TECHNO REFERENCING . . . . .
73's de Edd
A metal part in the cycling mechanism for a carousel came off and I can't determine where it goes without an exploded parts diagram.
Thanks,
Doug
Thanks 73's de Edd but my protection software will not let me download the library software. Is there a download pdf available?
Doug
