Keypad with 3 pin hall effect sensor
You can try using an Opto Coupler to replace the mechanical switches in the 3x4 array. The Opto could be triggered by the Hall Sensor output.
So, I would wire each sensor to an opto and wire the optos in a matrix like i would on a standard keypad?
I've always wanted to get into working with arduinos and I thought making a small keyboard would be a cool start. Then I got those sensors for cheap and thought that would be fun but I ran out of pins. I looked into multiplexing but it seems like you can only press one key at a time which isn't very ideal.
I'll read up on the opto couplers more and see if I can use them. Thanks a lot for your suggestion.
If I understand this right, each opto needs an led to turn it on? What if instead I just wire the output using diodes. 1 for each column and row. Would that work?
Yes
Yes. The Hall Sensor cannot drive the Opto's. You will need to interface a CMOS Buffer to drive the OPTO's.
Can we have a schematic of what you propose?
Please excuse the poor drawing, I didn't have graph paper. The 4 orange boxes are the sensors. I have 2 diodes on each output. The sensor should send a signal on the column diode and the row diode, but no other column or row should be affected since they are all on diodes.
Is that a Keyboard Matrix Decoder on the Top Right?
My Understanding is that the "ROW" voltage is reduced and the "COLOUMN" voltage is increased when a Key is Pressed (or the other way ). I don't think the "Diode" setup will work.
The box in the upper right is supposed to be a teensy. Which I could use to decode the matrix. And it looks like you are right, one seems to be pulled low and the other high. Back to the drawing board I guess. Thanks for the help.
Are you keen on a 3x4 matrix setup?
Why not a Decimal to BCD encoder?
The 3x4 isn't a must, only using it so I have enough pins on the teensy. The decimal to bcd encoder looks interesting. Never heard of that before so I'll have to look into it. Thanks
