JVC VHS hrs5500 power supply help needed
G
gasper
Hi
Would like to fix two JVC switching power supplies...
Both have the same problem. Supply starts and switches OK but some voltages
are missing or fail under load.
The supplies are of the big old JVC type in the back right of the VCR which
consists of two boards with the connections and maybe fault on the left
(secondary) side.
Symptoms :
VCR loads casette but FF or REW stop after a few seconds. Drum does not
start, sometimes it does but power button flickers and capstan does not
start.
Most of the time the record level meters fail or flicker.
Have replaced the brown 105C electrolytics without sucess, have changed
whole power supply with one of a good svhs... former dead one works, so
fault is definitely in the power supply.
Have no schematics but two of them with exact same fault so believe it is a
known fault.
Would be very pleased to have help and or schematics
Merry Christmas and a Happy new Year
Michael from Austria
Mark D. Zacharias
gasper said:
Hi
voltages are missing or fail under load.
which consists of two boards with the connections and maybe fault on the
left (secondary) side.
Symptoms :
start.
a known fault.
You're missing one or more caps. Don't know your model, but many JVC's had
bad 120uF at 6.3 volts caps bad, along the lower edge of the power supply
board. I just replace them with 100's or 220's, doesn't seem to make much
difference.
Mark Z.
G
gasper
Thank you mark,
I have often heard and researched the solution with the bad 120uf 6.3V
Cap.....
Unfortunately this must refer to a newer generation of JVC VCR,s , I believe
the VCR,s with the generation 15 drives and the funny loose tape guides....
But mine are all generation 12, the 3 motor drives with the old two pcb
power supply in the right corner. The pcb has partnumber 10166 regulator
pwb and switching pwb
Model Numbers are HRD 950 or HRS 5500 which use this kind of supply.
Of course I could try to replace all electrolytics but I even tried to
replace all 105C types in the secondary without sucess and I have problems
to get caps which are 105C and fit physically. It seems that the supply
fails under load.
Who has experience with this power supplies ?
Who can help ?
Thankyou
Michael
Similar threads
W
Replies
10
Views
3K
William Sommerwerck
W
Replies
2
Views
1K
David Farber
