JVC HDTV AV48WP30 - Red Tint / Lines in background .... Redness in the picture
tterrag smis
I have a JVC AV48WP30 HDTV. It has run flawlessly for the last 1.5 years.
Today my wife and 1 year old were near it for an extended period of time
(she was working / he was playing). When I sat down to watch TV tonight,
everything was all reddish.
Normally, when I switch between inputs (reg. TV, DVD, Digital Cable) the
background shows up as Grey in color. Now it is Red with Red curved lines
all over. While trying to watch several shows, I could see the reddish
curved lines (very lightly) during the darker (ie night-time) scenes.
I switched everything to B&W image and can still see the red lines.
Any ideas? Playing with the Tint helped a little, but not much and the
background still appears reddish.
My wife swears that our son didn't touch the TV - only the remote.
Hopefully I can fix this with a little guidance from you all and not have to
pay an arm and a leg I can't afford.
Thanks Much!
Garrett
One or more components has failed to the red driver or crt circuits.
Simply needs troubleshot by a qualified and trained technician to
determine the component failure in order to have the failed part
replaced.
Without some technical troubleshooting information, anything other than
call out a technician for an estimate of repair is simply not possible.
Given that it is a newer HDTV set, It is strongly recommended you call
someone who is JVC authorized for repair as they will have the service
manual and JVC training already on the set.
Rono
Likely that you have a bad red picture tube! I have done a few
of these! You MAY be able to turn down the red screen drive
behind the front cover, but more likely it's a tube! Rono.
Rono.
jango2
Could be that your son pressed a sequence of buttons that sent the tv
into service mode and then he mis-calibrated it .
tterrag smis
That is entirely possible - I did some more tweaking and manage to get an
"acceptable picture" - not like it was, but the red isn't as noticable.
The way I have it set now, cartoons (Simpsons, Family Guy) show up great,
while movies (LOTR on TNT) look faded and/or washed.
Garrett
