JVC DR MV1B , DVD/VCR recorder
N Cook
Not my usual area but willing to at least look at it despite inglorious
reputation googling about.
Owner was prepared to live with having to press on/off ten times from cold
before it would settle into on/standby but now there is a sound problem.
After 2 days powered up all audio functions gradually fail to white noise,
ie play anything , record anything VCR or DVD or off-air.
I've located 2 SIL, LA.... (closely surrounded in tiny lytics so cannot
read) in area of board marked Audio In/Out , any suggestions. ?
I get the impression it was on left and right so trace power line back to ps
and selectively heat to induce problem.?
b
You've probably done it I imagine, but change all the capacitors in
the power supply secondary- these units tend to have abysmal
ventilation and hence run hot. This gives rise to all kinds of weird
problems such as the on-off trouble you mentioned. from there, after
elimination you can delve into the trickier area of the audio circuit.
-B.
N Cook
General electronic repairs, most things repaired, other than TVs and PCs
http://www.divdev.fsnet.co.uk/repairs.htm
Diverse Devices, Southampton, England
Its a dual tuner jobby so worth cobbling something together
I've now read the numbers on this JVC DR MV1 audio SILs as LA7151 and
downloaded the pdf, they are dual amps so maybe just a problem with one
pack, but I'll trace back to the ps anyway.
There is certainly browning of the pcb around the ps primary side driver?
STR G6653? and browning to a lesser extent on the heatsink/pcb mounting
areas, despite a reasonable size heatsink. The owner actually suggested
putting in another or bigger fan. I will try and find what a Sharp PQ5EV3 is
also in the ps
N Cook
N Cook said:
to
also in the ps
10.1V supply to the audio amps using an E-line 300mA pass tranny and a 10V
smoother in the ps. Will uprate those and choke back the easy air supply on
on the wrong side of the ps to force a greater fraction over the SMPS driver
and add heatsinks to the 2 unsinked regulator devices. The fan seems
powerful enough despite its small size, just the internal air run seems
misdirected as though the ps was the wrong way round, the primary side is at
a blocked off dead end almost and gaping holes into the rest of the chassis
at the other end.
N Cook
I RTFM and this m/c blinks for 50 seconds from initial plugging in by
design.
Made the changes, will have to see in 2 days time whether repaired.
