My 80's JVC cassette deck no longer switches off at the end of a tape. I found a small metal plate next to a solenoid that disengages the mechanism when pressed, so my guess is that something is failing to activate the solenoid. The solenoid activates and stops the deck when the power is switched off, so I guess that it's okay. There is also a hall-effect sensor on the tape counter that does seem to produce a voltage pulse as the tape moves (I only have a digital meter, so it's very hard to measure, but it looks like there is a pulse of about 10V every second or so, although I'd have thought that was a high output for such a device). So my guess is that there is something between the sensor and the solenoid that is failing to switch it all off. Does anyone have any ideas?
Platforms
Content
