JVC 56" HDTV scratch on screen
b w
Is there any remedy for fixing scratches on big screen tvs? it is a
rear projection tv, the replacement screen is 460 bucks from JVC, i can
just replace that if i need to but i would rather try to make the
scratch less noticeable...
it feels pretty deep but i cant really tell, it mainly took the anti
glare off i think, please help i just want to minimize it if at all
possible
Brandon
Meat Plow
possible
Brandon
Really nothing you can do that won't mar the surface further.
Art
Is the scratch on teh Lenticular Screen or on the Clear Screen Protector?
If the mar is on the protector, optical quality plexiglass can be cut to the
size of the protector and used.
However, if the mar is on the Lenticular screen then buying another screen
is the only answer.
JR North
Try filling the scratch with thick CA. Will take some dexterity, and
perhaps a fine needle and mag glass. Can't say how it will affect the
optics. Maybe try a small area for test.
JR
James Sweet
possible
Brandon
Some Novus plastic polish might do the trick, but you'll probably have
to polish off the rest of the anti glare coating.
JANA
It would be nearly impossible to properly polish out the scratch and not
have any visible damage. When polishing, you will also be removing any
anti-reflective coatings.
There are polishing compounds that will work with Plexiglas, but on most
plastics, they may cause hazing or cloudiness. For an optical surface as
like on a TV screen, this is not practical to polish out. In any case, you
will end up having to replace the screen to fix it properly.
JANA
_____
possible
Brandon
Malissa Baldwin
possible
Brandon
throw it in the dumpster and buy a Protron, nerd.
