join servo signal wires
I have two servos and want them to move at the same time. would it work if i join the two signal wires together and just feed them the same piece of code?
This should work, provided the output of the servo driver can supply enough current to drive two servos simultaneously. Give it a try, the risk is very low.
I very much doubt that you will have success if these are PID positioning loop servo's, each has to have its own control loop.
In a motion control system it is done with electronic gearing, but this also requires individual drives.
It can be done with stepper motors.
What trajectory controller are you using?
M.
