Hi!
I have designed, measured and tested an amplifier which pre-amplifier consists of JFETs (BF245A) only, the transistor type for the power stage (2SK175) has however been chosen to be made of MOS-transistors, this is mainly due to the fact that I want Class B only and to "strangle" Power JFET (which I actually own a couple of due to the kindness of this nice forum) is more difficult than to strangle MOS because all you need to do is to go below pinch-off.
I am a bit proud of this design because it shows several good behaviours.
The whole thought with it all is to use it in a guitar amplifier (which I am building).
This is however even more interesting (if I may say so), it seams like the warm and nice sound of a clipping tube-amp actually has NOTHING to to with tubes, it seams like it is the output transfomer that gives this nice sound (I have FFT analysis's showing this)
To me it is kind of strange because when you calculate with it, ONLY odd harmonics is being generated while I have heard that the nice harmonics are even.
Once upon a time I built a 2X6W Williamson amplifier and it was reallly cozy to hear it clip at those tiny 6W, this is also an experience that is, power is over estimated (because I had a blast with my 6W).
Anyway, I have managed to make my KJA work, I started by using a current generator to crank the gain up but it was so unstable that I switched to a common (drain) resistor instead, this did however make my gain drop about a magnitude but a friend of mine at my swedish forum told me that a guitar amplifier actually does not need to have so much gain, input sensitivity could be as high as 500mV, he told me.
Of course this amplifier (KJA) uses an output transformer (which is kind of unique för semi conductors), the transformer is thus eliminating even harmonics and passing on odd harmonics (or so I have been told).
The output transformer (OPT) is not that perfect, I have wound 2X100 turns of 0,7mm Cu as primaries on a 3F3 ferrite toroidal core, a stupid choice actually because it saturates early with B, so I have bought a pair of iron-powder toroidal cores also, they can withstand some 3 times as much B but the 3F3 is readily wounded and I really don't want to wind again (even if I have some tools, maybe you can call it needle-shuffles).
Right now I don't know what to do, the only thing I have learned is that when it comes to electric guitars, there's not much information below some 300Hz.
300Hz is also about the saturation frequency for my 3F3.
Best regards, Roger
![DSCN3632.JPG DSCN3632.JPG](https://makerv2.webteractive.co/forums/data/attachments/40/40267-b136caa9cdbf0e7ae305fa7eaa62600d.jpg)
Best regards, Roger
![KJA_sch.png KJA_sch.png](https://makerv2.webteractive.co/forums/data/attachments/40/40268-066d47e69483f7eba4d4e11f2d2e2ab7.jpg)
![DSCN3191.JPG DSCN3191.JPG](https://makerv2.webteractive.co/forums/data/attachments/40/40265-7bcced25e6251571eb0ce71e7267f507.jpg)
![DSCN3195.JPG DSCN3195.JPG](https://makerv2.webteractive.co/forums/data/attachments/40/40266-bf98ff603ad20956e6895c5b966500fb.jpg)
