I have an extra high pressure coil and now have a notion to construct a Jacob's Ladder. At first blush, I had no idea why the active arch would begin to travel upward along the ladder sides, increasing the length of the arc and apparently the resistance thru which the arc must travel. Seems to contradict the "path of least resistance" principle. Further rumination brought about a theory that, as a conductor (metal in this case) increases in temperature its impedance also increases. Therefore, the arc is seeking a path of lesser resistance by way of cooler metal. However, I vaguely recall hearing a theory touting an over abundance of ions is created by the arc and are elevated by the rising heated air produced by the arc and the arc finds that ion track to be a lesser resistance, and follows it. I believe both effects come into play.
Platforms
Content
