Hi all,
I am hoping one of you kind intelligent people could help me with a circuit I have made which occasionally does not work properly.
The power switch on the right of the drawing enables the circuit to start with then the circuit is held on by the relay. I can now turn off the power and it remains on, which is what I want. Now the module side has a trigger wire to a microswitch and when enabled it kicks in the other relay which drops the first relay out and still puts a supply to the PSU. Once the timer has run down it then reverts the module relay back to the original position which then turns off the power, Sometimes. The only thing I can see is I get an arc across the relay sometimes which keeps the unit energised again. Not sure what component I need to add to this to create a slight delay to stop it pulling in the first relay again. Any help would be much appreciated from the clever people out there.Thanks
