René
Presently I am ISP programming my various projects using the STK500,
which works well.
In the future I would like to program AVR chips in-circuit using a
dedicated piece of hardware, using the serial port - should work on
various windows machines, including my XP PC.
Here the confusion begins - Atmel does it using a dedicated processor
(as used on the STK500), but while googling I found several ckt's that
work without a cpu, just a buffer, or even no more than a few zeners
and resistors - but requiring more than just TX/RX.
These low part count solutions need dedictated SW, that mostly seem to
run under DOS.
If some body could shout me a valid combination of a simple RS232 -
ISP ckt + Windows / XP compatible SW to drive it (prog. hex file, set
fuses), I would be most grateful!
which works well.
run under DOS.
