Phil Allison
"David Nebenzahl"
** Scumbags like YOU need a bullet in the head.
..... Phil
..... Phil
"Ground" is a concept.Dave said:Of course.
Perhaps you could give the reasons why things *must* be grounded under all
circumstances. If you actually understand the dangers of this, of course.
Normally, I'd not waste my time trying to train
internet denizens.
The primary reason to want an isolation transformer to
troubleshoot a power supply is to work on the primary side.
Now, the KEY word is TROUBLESHOOT. What that means is that
the power supply has a FAULT in the primary circuit.
What's the fault? You don't know, or you'd just fix it.
How safe is it to troubleshoot that particular fault?
You don't know, 'cause you don't know what it is.
You're gonna RISK ELECTROCUTION based on the misguided
assumption that an isolation transformer keeps you safe.
YOU'RE NOT SAFE. YOU DON'T HAVE ANY IDEA WHAT THE PRIMARY
CIRCUIT IS, BECAUSE IT'S NOT AS DESIGNED. IT HAS A FAULT!!!!!!!
The node that the designer called common may not be common
at all. IT HAS A FAULT!!!! You should not arbitrarily ground
ANY node. It has a fault!!! (I'm skipping over the obvious
question, "what is ground anyway?")
An isolation transformer is not inherently bad. It can
provide a layer of protection. What is bad is the FALSE
sense of security
that the transformer makes it safe to poke around inside
a supply WITH A PRIMARY FAULT.
Dave Plowman (News) said:No it hasn't. Isolation transformers are still used for many safety
related reasons. But don't expect you to understand why. Obviously.
"Phil Allison"
Funny that was never on any service literature or diagnostic procedure
documentation I ever read. Nor would I have ever made it my own
practice as a first step thinking back 30 through 30 years.
However, I can't think of any case where the use of an isolation
transformer *increases* any hazard.
Dave Plowman (News) said:Seems to me some expect the use of an isolation transformer to be some
form of magic bullet that removes all risks. It doesn't. But can reduce
the sort of risk caused by one side of a mains supply being grounded. If
you then ground one leg of the output of that transformer by any means you
are back to square one.
Well, I sure can. When they listen to someones advice that it is OK to
touch either side of the output of the xformer. As Phil pointed out if
there is a problem that could be lethal
That is in no way a fault of the isolation transformer.
Dave said:Seems to me some expect the use of an isolation transformer to be some
Becomeing complacent in or unconcerned with electrical hazards is a
fact of life (or death.)
But then again this is an internationally mirrored forum so I don't
really try to pawn off my particular service procedures as the gospel
where the diagnostics flow chart may be much different in certain
regions of the globe.
I have been thinking about it. The MAIN purpose of an isolation transformer
is to make it non isolated by making a NEW neutral close to the device
being powered. The main purpose of an isolation transformer is noise control.
Now we have us tecks who all our lives have learned isolation and that stuff.
I taliked to the people at Tripplite and verified ALL their isolation
transformers ARE grounded. Read the paragraph, and yet it says above, "Complete
Isolation"http://www.tripplite.com/en/products/model.cfm?txtSeriesID=325&EID=1
3...
Also look throughhttp://www.tripplite.com/en/keyword-search.cfm?q=isolation%20transforme
r
The isolator you buy from MCM is very unlikely to have the secondary grounded, but
I really can't verify that.
In reading PC Power Protection by Mark Waller, he
pointed out their is a NEC requirment for this grounding.
I have not found an exact description in the code. There is about 75 references
in that book, but no index marks. Man, I should sell that book !!!! Big Bucks.
greg
I have hooked things up with isolation and later found things like a motor
short.
Works fine with the transformer.
I didn't always first check the customers explanation and plug something
in right away before doing anything, but I do it now.
