E
Eric R Snow
If I want to raise the voltage to an ac 120 volt motor by, say, 12
volts, is this a way to do it?: Use a 120 volt primary, 12 volt
secondary xmfr with the secondary winding rated at or above the amp
rating of the motor. Then connect the 120 volt primary leads to 120
volts. Then connect one lead of the secondary to one lead of the
primary. Finally, one lead of the motor is connected to the other lead
of the secondary and the second lead to the lead of the primary that
is not connected to the secondary. This will result in either a
voltage drop or voltage gain of 12 volts. If the voltage drops then
the secondary leads must be reversed. Are these statements correct?
Thank you,
Eric
Thank you,
Eric
