Hello, this probably sounds like a crazy idea, but I have to try . I'm trying to turn a full-sized LED (10mm in height and 5mm in diameter) into a smaller LED. I've used a Dremel to cut and grind it to 5mm in width and height and it works fine. Is there a way to polish the LED semiconductor so it wouldn't absorb light as well as heat?
I have no idea what semiconducting material it is . The light is blue and according to Wikipedia it can either be gallium nitride or indium gallium nitride.
Any ideas would be appreciated.
P.S. The obvious idea would be to buy smaller LEDs instead of cutting the large ones . I'm just curious.
