So I have been working on a project that involves using ball bearing tilt switches. Which are fine. But in programmer's language I have to many IFs to in my equation that I need to solder together so many tilt switches at so many angles I that am getting dizzy, and am sure I will miss an angle.
i.e. I'm not just looking for tilting forward at 15 degrees on one axis. I have to take into consideration every degree in a 350 degree 3D area. So you get the idea you many tilt switches I would need.
All this would be easily solved if I could use a liquid switch and gravity. Obviously mercury is toxic and expensive.
I started with citric juices...too weak. Someone mentioned adding salt to vinegar. Am thinking maybe that would work, but would it stay in solution?
And then I realized maybe I should ask here before I keep experimenting.
Anyone know of any liquid conductor that's readily available, not expensive, and that conducts as well as mercury (or as close to it) etc. etc.
Thanks ahead,
Sergio
ps: this is a very low voltage project....6V. So the less power I lose, the better.
Thanks ahead,
Sergio
