Hi There,
I need some guidance on whether or not I have selected the right transistors and their resistors for there bases.I lost all my books in a big flood that I would use to learn this stuff. I need to drive 500mA to 25 RGB LEDS and the output of this AVR chip can only supply 20mA max on a 5.15V supply. Instead of using HFE values i just selected based on the base current
saturation took took from data sheets and took into voltage drop across the transistor at different angles when selecting my base resistors. I couldn't find just 1 transistor to do the job so I selected 2. BC547 NPN draw 5mA to BE(SAT). BC327 PNP takes more than 60mA from the NPN to the base and supplies more then 500mA to transistors( all that those gains i pulled straight off the data sheets). Some said I was way off saying I don't see any HFE values. can anyone advise me if my thinking is flawed and if so show me the right way or at least correct my reasoning ? thanks in advance. I put my workings on the drawing.
![led rbg array 2nd draft.PNG led rbg array 2nd draft.PNG](https://makerv2.webteractive.co/forums/data/attachments/18/18920-9e26285cd8ef017de354b1c5f8f6236c.jpg)
