Is a newer car radio to integrated to be pulled for another?
davidlaska
My Toyota cressida 86 is dead but the AM/FM stereo with build in
equalizer and tape player and 4 speakers is better than nothing in my
other car. I could not figure out a lot of the wires so tried looking
through my factory service manual and a separate electrical manual for
the cressida. The wiring diagram was very busy. Before I dive into
it, I need to know if these units are tied into the specific car so
much that it would be nearly impossible to move the unit and have it
just play tapes and radio? If possible, that would give me the extra
push needed to trace all those wire throughout the harness ( I have the
whole dash out presently for other things I am doing).
3
3T39
Hello, davidlaska!
You wrote on 31 Aug 2006 21:25:51 -0700:
d> My Toyota cressida 86 is dead but the AM/FM stereo with build in
d> equalizer and tape player and 4 speakers is better than nothing in my
d> other car. I could not figure out a lot of the wires so tried looking
d> through my factory service manual and a separate electrical manual for
d> the cressida. The wiring diagram was very busy. Before I dive into
d> it, I need to know if these units are tied into the specific car so
d> much that it would be nearly impossible to move the unit and have it
d> just play tapes and radio? If possible, that would give me the extra
d> push needed to trace all those wire throughout the harness ( I have the
d> whole dash out presently for other things I am doing).
The built in Radio sets are not really specific to any one car, but the
plugs and sockets are, sometimes differing between similar car models. If
you have the radio unit out of the car and it has wire tails then you can
just cut off the plugs and connect up using universal screw type connector
blocks. Although it may look confusing, it's not really so hard to figure
out. First of course you need power (12V+) usually red. Then the negative
(chassis ground, usually black 12V-) . on modern sets there is often a
power connector for an electric antenna (often yellow but not always) then
there are eight wires for the four speakers (a live and a ground for each
speaker) god only knows what colour these will be, but the grounds are often
the same colour, also, if you have a multi meter - the four speaker grounds
will likely be connected electrically to the chassis ground. The antenna
connector will be obvious as it will have a co-axial socket on the end. Try
it rigged up before you mount it into another vehicle. Don't forget to use
an inline fuse around 20 - 30 amp. Be aware that a lot of units need a code
to be entered after power loss. Just a thought, but these things are so
cheap now, you could probably pick a decent one up from a breakers yard for
a tenner or so, then it wouldn't matter too much if you set it on fire.
Before you start, wait to see if another poster thinks of something I may
have forgotten.
With best regards, 3T39. E-mail: [email protected]
Bennett Price
Add yet one more wire for an 'always-live' wire to keep station memory
(and clock-if present) intact.
3
3T39
Hello, Bennett!
You wrote on Fri, 01 Sep 2006 15:54:25 GMT:
See what I mean :^)
Dave Plowman (News)
See what I mean :^)
Possibly a dimmer feed from the car instrument lighting. Feed to aerial
amp if it has a rear window type. Or it might have an external power amp.
Some also use the display for non-radio things - but this should be
obvious.
K
Ken Weitzel
3T39 said:
Hello, Bennett!
See what I mean :^)
Gets even worse... :)
Power antenna control?
davidlaska
The bottom line is , It can be done. The extra wires can be dealt
with as I listen to music with it. But what is the code deal again, is
it some disabling thing rendering it useless in another car? Is it a
push once and reset or some complicated factory rom flash reset or
worse?
3
3T39
Hello, davidlaska!
You wrote on 1 Sep 2006 13:00:29 -0700:
d> The bottom line is , It can be done. The extra wires can be dealt
d> with as I listen to music with it. But what is the code deal again, is
d> it some disabling thing rendering it useless in another car? Is it a
d> push once and reset or some complicated factory rom flash reset or
d> worse?
Yes the coded radios use an eeprom to store a code number which has to be
re-entered after power is removed . they are supposed to discourage theft
but only ever caused legitimate users grief when they simply forgot the
code after a few years. Ford radios were the worst for this, but other
makers embraced the technology for a while, I don't know how common they are
nowadays. Of course, thieves never worried about it, as the right equipment
can erase and re-code the eeprom and they always know a scally who can get
it done cheap. And incidentaly this is the 'always on' power wire that
another poster mentioned.
davidlaska
3T39 said:
Hello, davidlaska!
d> worse?
Could I further assume that removing the battery from the car would
trigger the code, I have removed the battery to exchange it and did not
have to enter a code. I hope this is it.
jakdedert
Go to an auto parts store and look at the diagram for an adaptor
specific to your car. They sell these for adapting aftermarket players
to generic equipment. It will have the wire code written (usually on
the packaging, but you might have to buy it, open up the instructions,
copy the diagram, repack and return).
jak
jakdedert
I don't 'think' that Toyotas of that vintage had coded radios; but I
can't be sure. I know that my '90 Corolla is not encoded.
jak
t.hoehler
jakdedert said:
Go to an auto parts store and look at the diagram for an adaptor specific
to your car. They sell these for adapting aftermarket players to generic
equipment. It will have the wire code written (usually on the packaging,
but you might have to buy it, open up the instructions, copy the diagram,
repack and return).
jak
If the new radio has 'high power' outputs, be careful of speaker grounds. On
my car, thre are two leads to each speaker, no commons to the chassis.
Reason is that the radio uses a bridged output circuit which does not return
the speaker minus to chassis. If you ground the minus lead to chassis, you
risk damaging the output IC's.
regards,
tom
davidlaska
regards,
tom
I have the toyota,s factory electrical system from toyota and also the
shop one, I have not found any mention of a code. Believe it or not,
there are no take apart diagrams or sections for this.
3
3T39
Hello, davidlaska!
You wrote on 1 Sep 2006 15:00:12 -0700:
d> 3T39 wrote:
??>> Hello, davidlaska!
??>> You wrote on 1 Sep 2006 13:00:29 -0700:
d>>> The bottom line is , It can be done. The extra wires can be dealt
d>>> with as I listen to music with it. But what is the code deal again,
d>>> is it some disabling thing rendering it useless in another car? Is it
d>>> a push once and reset or some complicated factory rom flash reset
d>>> or worse?
??>> Yes the coded radios use an eeprom to store a code number which has to
??>> be re-entered after power is removed . they are supposed to discourage
??>> theft but only ever caused legitimate users grief when they simply
??>> forgot the code after a few years. Ford radios were the worst for
??>> this, but other makers embraced the technology for a while, I don't
??>> know how common they are nowadays. Of course, thieves never worried
??>> about it, as the right equipment can erase and re-code the eeprom and
??>> they always know a scally who can get it done cheap. And incidentaly
??>> this is the 'always on' power wire that another poster mentioned.
??>> With best regards, 3T39. E-mail: [email protected]
d> Could I further assume that removing the battery from the car would
d> trigger the code, I have removed the battery to exchange it and did not
d> have to enter a code. I hope this is it.
Yes, that's quite right. If you have removed the battery in the past and the
radio worked fine after replacing the battery, then your radio is not coded,
so that's one more thing you don't have to worry about.
davidlaska
3T39 said:
Hello, davidlaska!
d>>> or worse?
Thanks for everything
