O
O. P. E.
I built a pulse generator that produces ~1.5 ns pulses that go from
0-3V. (Use Linear app note 98 if you want to build one.) I would
like to put it into an RF amp to produce the 7V pulses needed for my
application. My problem is that my amp is an inverting amp. Thus,
when I put in my positive pulse (actually attenuated down for the
amp), it produces a negative pulse of ~4.5 V (corresponding to the
bottom rail).
I thought that I could switch the polarity of the SMA connector on my
board -- attaching ground to the middle pin and the pulse output to
the case. However, I don't think this will work as the ground from
the amp and scope will then have to float. I thought of using a NOT
gate, but wouldn't that just give a pulse that goes from -5 to 0?
Also, the gate would likely increase the pulse width, which we would
like to keep as short as possible.
What would be ideal is to have some simple device that takes a
positive voltage and flips it to negative, while keeping the pulse
width short. At low frequencies, an op-amp could do it, but I'm not
sure of any op-amp that will do it at these frequencies. Does anyone
know something that will do it? Has anyone done something like this
before?
Obviously, it would be better to just use a non-inverting amp. The
spec sheet on the amp (JDSU H301) doesn't even mention that it is
inverting. Are all Optical Modulator Driver amps inverting, so that
it is just an understood?
bottom rail).
before?
