naniboujou
The LCD backlight is out, but the LCD itself is working (I can see its
image under bright light). There is only a very low voltage at the
output of the inverter (about 25 volts ac), even when disconnected from
the tube. There is 14.8 VDC coming into the inverter. It seems
reasonable the inverter has the problem (INN SUN 5313S-02 Rev:03).
Anyone know where I can get one? -- used but working would be fine. But
I have another idea: What if I don't use an exact replacement? The LED
setup may not match, but this is an old model and I could live without
that. Anyone tried this kind of a substitution? There is a fairly wide
range on the fluorescent tube specs (Turn on voltage, operating voltage)
and of course I have no info on what this one wants to see. If I error
on the low side, how critical is this? Where could I get an inverter to try?
