Jeff Stout
Does RS-232 need a Zener Barrier, or can I send it out raw?
Jeff Stout
Jeff Stout
Jeff said:Does RS-232 need a Zener Barrier, or can I send it out raw?
Jeff Stout
Robert Baer said:1) What the hell is a "Zener Barrier"?
2) The RS-232 spec allows a fault up to 25V difference between thear
driver and the receiver, if i remember correctly.
However, in practice, there have been almost zero ICs that would work
anywhere near that offset.
I just signed up to do the stuff required to design intrinsic and explosion
proof gear, so hopefully I will know the real answer soon!!!
The said:Now I am by far no expert when it comes to intrinsic safe devices, but I
thought that the requirement was for the powersupply to be intrinsically
safe. [...]
safe. [...]
Intrinsic safety is not related to devices, but to electrical circuits.
It restricts the voltage, current, and stored energy in a circuit so
that generation of sparks is "impossible".
Anytime you connect a circuit that is not intrinsically safe to anything
within an "ex" area, you need those barriers to limit voltage, current,
and energy in the circuit that reaches into the ex area.
Back to the OPs question, I would not rely on RS-232 signals to
be intrinsically safe, especially if I didn't know how exactly the
driver circuit is built and/or protected. Particularly, you won't
get an Ex-i certificate for the device that has that RS-232 interface.
Jeff Stout said:Does RS-232 need a Zener Barrier, or can I send it out raw?
Tilmann Reh said:Back to the OPs question, I would not rely on RS-232 signals to
Adding a dual-port barrier gets you on the safe side.
Dipl.-Ing. Tilmann Reh
Autometer GmbH Siegen - Elektronik nach Maß.
http://www.autometer.de
In a world without walls and fences, who needs Windows and Gates ?
(Sun Microsystems)
Jeff Stout said:But any chip that calls itself an "RS-232" driver chip must have a certain
impediance and limits in voltage and current. I mean, when was the last
time
you saw a RS-232 wire generate a spark (which is the key question)?
But we are not talking common sense here. We're talking about huge
Bureaucracies (CSA, UL) which have rules.
time
nospam said:Everything needs a zener barrier that it is the whole point. You rely on a
barrier to protect the area from electrical energy which could cause
ignition and you rely on the barrier to fail safe.
