Intrinsic Safety
BIGEYE
Can anyone point me to a website that demonstrates on how to select the
correct intrinsic safety barriers to suit instruments and cables (showing
cable calculations) for an intrinsically safe system design.
I have googled through many pages, but have been unable to find what I am
looking for.
TIA
SQLit
looking for.
TIA
intrinsic safe is a huge galaxy. There are no general rules. There are only
specific requirements.
Intrinsic safe in a flammable gas atmosphere (hydrogen for example) would be
some what different than a flammable liquid situation (gasoline for
example).
Placement, voltages, current, are all considerations and apply.
Narrow your issue down to a county and maybe we can help
John B Smith
A useful reference book in UK is
Intrinsically Safe Instrumentation: a guide
by Robin Garside. 3rd Edition Revised 1997.
Covering this important protection concept in detail, this book explains the
key criteria including associated apparatus, system selection and design,
cabling, earthing, certification etc. The use of Simple Apparatus (which may
be installed without certification) is explained and the procedure for
assessing systems which do not have system certification is covered in
detail.
325 pages, extensively illustrated. A5 format
ISBN 0 9516848 1 7
Jaybetec
BIGEYE
only
be
example).
Country UK
Zone 1
Gas Classification IIC
Instrument Supply 24VDC
Loop Current 4-20mA
This is an academic exercise that I will need to do for college. Only need
to look at how we select IS barriers for a particular instrument,
considering supply voltage, current, etc.
Then need to select the correct cable, considering cable capacitance based
on conductor size/cable length, etc.
TIA
Paul E. Bennett
BIGEYE said:
[%X]
Country UK
Zone 1
Loop Current 4-20mA
TIA
Take a look at:-
http://www.hse.gov.uk/comah/sragtech/techmeasureaclas.htm
I hope your college library can give you access to some of the EN500xx
standards referenced by this document as the finer details will be in those
documents (probably EN50020, 2002).
Other things that may be worth searching on are:-
DSEAR and ATEX.
Paul E. Bennett ....................<email://[email protected]>
Forth based HIDECS Consultancy .....<http://www.amleth.demon.co.uk/>
Mob: +44 (0)7811-639972
Tel: +44 (0)1235-811095
Going Forth Safely ....EBA. http://www.electric-boat-association.org.uk/
BIGEYE
Paul E. Bennett said:
(showing cable calculations) for an intrinsically safe system design.
am looking for.
TIA
[%X]
Country UK
Zone 1
Loop Current 4-20mA
need
based
TIA
Take a look at:-
those
DSEAR and ATEX.
404 error
Steve Y
Whilst Robin's book is OK, there are also free application notes
available from http://www.mtl-inst.com/mtlsupport.nsf
Don't forget that when choosing a barrier for an application, you need
to find a barrier/instrument combination that is safe but one that works
in the way you want it to as well.
Steve
