Nigel
I have a JVC AV-28F1EK, which although around 15 years old is in immaculate
condition and works well with the exception of the following fault.
It is used a spare set, primarily for my children to play their Nintendo
Gamecube.
The set will run perfectly for days and then whilst in use it will switch
off. The TV is still powered and the 'on' LED responds to the standby
button on the remote but there is no sound or picture.
If I switch off and leave for 15 or so minutes it will start working
probably for days or even weeks before the fault occurs.
There doesn't seem to be any reason to when the fault occurs. It could be 5
minutes after switch on, it could be hours.
I'm loathed to bring in a repair man because I know when he arrives it will
work fine and probably continue to do so for the next 2 weeks - so I will
end up with a call out charge and a 'no fault found'.
Anyone have any ideas?
Is this a documented problem with this set?
Can anyone point me to areas or components I should investigate/replace?
I have a good understanding of electronics (degree qualified) but don't know
televisions that well and don't have a scematic. I guess I'm looking at a
dry joint, open circuit resistor or dying electrolytic but I've no idea
where to start looking.
Any help appreciated.
Cheers,
Nigel
Gamecube.
Cheers,
Nigel
