MarkAren
Hi All,
An interesting item you may be able to help me identify.
http://www.geocities.com/markaren10/misc/opto1.jpg
14mm dia, 7mm high, 6 leads, clear lid, writing on the side "12188",
no manufacturers mark, logo or name.
The device is three layers;
- Pelitier device, pins 1 & 2 (bottom)
- Thermistor, pins 4 & 5
- Opto device, pins 3 & 6 (top)
Measure resistance between 4 & 5 (nominally 10k). Apply 500mA between
1 & 2. Resistance goes up or down depending upon direction of current.
So there is a method to temperature control the opto device. The whole
unit was mounted on a heatsink.
Opto device: 500k nominal resistance, changes to 400k with a very
bright light. It might be IR sensitive (?) Does not appear to generate
any voltage and have the same resistance either way around so
apparently not a semiconductor.
I assume that the opto device is cooled by the Peltier device (and
hence the need for the external heatsink).
Anyone seen anything like this before ?
Regards,
Mark
Regards,
Mark
