shuteng
Hi all,
1. I learnt in my varsity that the drain and source of a transistor
can be interchanged when drawing the layout (IC) of a transistor. Have
been thinking about it for sometime and I conclude that the drain and
source of a MOS transistor is equally doped hence, they can be
interused unlike that of (collector and emittor of BJT). Is my
hypothesis correct? If so, does it also means that the source and
drain can be interchanged on schematics?
2. In microelectronics, if a nMOSFET is used as a pass gate, does it
matter whether I connect the (driver) signal to the drain or source?
What are the minimum gate voltages needed to pass the signal from the
driver to the other devices(assuming 1V Vt)?
a) _|_ b) _|_
signal=3V ___| |___ signal=0V ___| |___
D S D S
c) _|_ d) _|_
S D S D
I apologise for my long questions and thanks in advance
shuteng
a) _|_ b) _|_
D S D S
c) _|_ d) _|_
S D S D
shuteng
