Ok guys/gals-
I need some help with the lingo. In my mind it would be called a bypass gate but that isn't looking to be the case. What would an IC with a PNP and NPN transistor with shared Bases be called?
Basically the main current travels path A until the switch current is applied to base of both transistors. The NPN switches on to open path B through the circuit and simultaneously the PNP switches off to close the path A.
Thanks!
Thanks!
