Integrated AGC 100kHz-10MHz
H
Hammy
I have a signal between 100kHz to 10MHz sinusoidal DAC output. The
signal starts out at 650mVpp low frequency with a small DC offset of
about 10mV. As the frequency increases the DC offset increases and the
pk-pk voltage decreases. At 10 MHz my signal pk-pk has deteriorated to
about 100mVpp with about 500mV DC offset.
Are there any single chip or small parts count solution AGC that can
maintain a constant 650mVpp output under the above conditions.
I've been goggling AGC and haven't had much luck other then 100 part
count schematics there must be an integrated version?
F
Fred Bartoli
Use a better output opamp (yours must be... well...) and adjust the
circuit response so that you're within the specs.
Oh, is your DAC up to the task too?
F
Fred Bartoli
Also check your sampling frequency (DAC sinc response).
But the 500mV offset surely indicates your opamp choice is bad.
H
Hammy
It's not an op-amp it's the DAC on an AD9834 DDS IC. I want to feed
the signal to an LPF then to an AD8045 for final amplification. I want
to use the AD8045 for variable gain selectable by a POT in the
feedback loop. This is easier done using a consistent input signal. I
think I may have found something AD8330ACPZ.
I'm using the 50MHz part when I use the 75MHz part it probably wont be
as bad.
I cant find any specs in the datasheet about offset vs frequency. It
is possible I damaged the part inadvertently while testing on the
breadbaord;)
Anybody use AD's DDS IC's is this typical?
H
Hammy
as bad.
breadbaord;)
It seems that this is normal for these parts. This guy is using an
opamp (IC6 OPA843) to adjust the output of the DDS before the LPF.
SEE
http://i46.tinypic.com/65v4ut.png
I want to be able to use an AGC Wideband Op-Amp there instead.
Joerg
Yes, but it's expensive:
http://www.analog.com/static/imported-files/Data_Sheets/AD8367.pdf
If on a budget you could build one around a uA733 or similar chip, add a
simple detector and a FET as the gain control element. If your budget is
super-tight use a dual-gate MOSFET which allows the gain control range
you are looking for. One gate gets the signal, the other the control
voltage.
Here is another trick to save a buck: Characterize the signal drop
versus frequency. Then use a simple gain control stage and place a 2nd
DAC. This 2nd DAC is used to set the gain control input and is updated
whenever you update the frequency.
Jamie
If sounds like you have a cos/sin of your output shifting amplitude.
This would thus be the same as changing the duty cycle and causing
the offset you're seeing.
I wonder if you have a unity stage for the DAC to prevent excess
loading, do to load capacitance ?
This all maybe a shot in the dark but it's my shot :)
john jardine
With a 50MHz clock the signal would normally drop to maybe 500mV at 10MHz
but that's assuming you're measuring using a 10:1 scope probe with say 13pF
tip capacitance.
The 'FSadjust' and 'Rset' can be used for AGC. Put a DC 'level set' voltage
on the Rser resistor end that normally connects to 0V. (OV=max out). Idea is
to throttle the output swing to (say) 1/2 of normal, which then allows a
+50% increase to compensate for losses.
H
Hammy
What isn't ;)
I was thinking of putting a digital pot in the AD8045 feedback loop.
But by the time all is said and done 6 Bucks for the AD8637 looks
pretty good.Newark sent me out a 25% off flyer so it's a good time to
buy parts.
I'm using an AD9834 DDS IC to build my own signal generator controlled
from the serial port. The parts pretty impressive for $7 sine, square
,triangle output can perform various modulation with minimal parts
,ability to sweep frequency range defined step size and rate and a
75MHz clock. I know AD make much faster ones but a 10MHz output max is
good for me.
Trying to keep it in the $35 to $50 range. I was going to buy a cheap
$150 - $250 Chinese one but decided to build my own.
H
Hammy
tip capacitance.
Thanks John.
I'll try playing around with that.
Joerg
Jim said:
Years ago, I used a temperature-driven look-up table, controlling a
varicap, to make crystal oscillators as stable as oven-controlled...
without the power requirements of an oven.
You did WHAT? A LUT? Meaning digital stuff? <gasp>
Now go, stand in the corner, and be ashamed. Tsk, tsk, tsk ...
Joerg
Jim said:
The client, Saunders and Associates (builders of crystal testing
equipment) did the LUT. I did the analog and A/D/A interfaces.
Good. Your are redeemed. Welcome back to the analog club :)
JosephKK
Thanks John.
With all that has been said, i suspect a miswire or some circuit
problem. Both the DSS and the first OPA should be up to the task
(without the stated aberrations). Though it could very well be a
layout issue as well. Since the DSS is current output are you using
an appropriate termination and coupling to the OPA?
H
Hammy
Actually I'm embarrassed to say I had my probe on 1x (I know stupid).
I really have to stop doing that it's getting ridiculous.
I'm just working on the power supply now.
On the plus side I learnt a lot about AGC ccts and what's out there
for future reference.
Thanks to all who helped.
