Pimpom
When active power devices are operated at dissipations
approaching their maximum ratings (after including appropriate
derating factors, heatsink properties and safety margins), the
case-heatsink thermal resistance sometimes makes up a significant
part of the total J-A thermal circuit. Some devices like those in
variants of TO-220 and TOP3 packages are offered with a choice of
bare metal or insulated mounting tabs. Datasheets often do not
make any distinction between the two versions regarding their
case-heatsink thermal resistances.
Would it be reasonable to assume that the c-hs Rth of an
insulated case is about the same as that of a bare metal case
mounted with a mica insulator (using a thermal paste in each
case)?
case)?
