For the inside ceiling of my workvan:
So the LED light fixtures I bought from harbor freight use 3 AAA batteries in series or ~4.5V. There are two separate circuits of these on the fixture so all 6 lights be powered.
I'm not sure on the power draw (yet) but I need to step down my battery/alternator input (12.5-14v) to the 9v needed for the lights rigged up in series.
Alternatively, I could step up to 18v and wire all 4 circuits in series as well.
After a little research it seems that they sell "Buck converters" specifically for this purpose. I'd rather just solder a few components together from my home supply if I can do it a simpler way.
I know the linear conversion method is said to be inefficient and generates heat but I don't see that being a big problem considering I am only using these lights typically less than 10 minutes at a time.
Could anyone reference me a circuit or give me some pointers on this? Could I just solder enough diodes to induce a big enough voltage drop? I'm thinking 6 of them??? Would I also need to size a resistor?
