If you look at the drawing you will see at the top my inputs 110v, 12v and solar.
I can also add more batteries if needed. I will be running a mini-itx computer with a solid state drive (160 watts) and a ham radio (5-100 watts) depending on what’s needed to make contact. Most of the time this will run off of the car 12v but I need to be able to run off of 110v (generator) when that is an option. The internal Batteries should be able to run the radio on low power for a while if it needs to. Solar is for charging the batteries in down time and running the radio on low power. I will also have outlets for 110v and 12v so cell phones etc... can be charged from this box(when on 110v or 12v I have a 500 watt DC to AC inverter)
