I am studying transistor amplifiers, specifically for the moment
Common Emitter with fixed resistor bias. For example Vcc = 15V, Rb =
200K, RC = 1K, Beta = 100 , capacitor coupled input connected to an AC
signal +/- 0.5V for example.
I think that I understand the load line characteristic curve stuff.
Ic will be centered at 7.15 ma and Vce will be centered around
7.85V . I believe that Vbe will fluctuate between .65V and .75V and
Ib will fluctuate above and below 71.5 uA by some value ?? . I guess
this could be determined by plotting a diode curve.
My problem is with the capacitive input coupling and the current flow
and how Vbe changes from .65V through .75V as the book seems to
indicate. Every book and source that I have kind of waves their hands
and says that the capacitor removes the DC bias and allows AC to
flow. The way that I think is to draw many pictures of the same
circuit and think of instances of time with concrete values for the
voltages, currents, direction of currents all over the circuit.
I can see how a capacitor would allow current to flow back and forth
in a circuit containing a capacitor connected in series with a
resistor. I know that current does not cross the dielectric. But
what if you throw a diode (transistor BE) in series with a resistor
and a capacitor. I don't see how this would allow current to flow
back and forth. I guess I need someone to break it way down so that I
can understand it.
Any help would be greatly appreciated. Thanks.
can understand it.
