hello
using 2 non inverting opamp buffers (AD8620) to read the voltage across 2 resistors connected in series
1 reference resistor and 1 resistor DUT via reed relays (reed relays are switched in turn to read each resistor)
Output of opamp buffers feed an instrument amplifier AD8211
The input of the buffer opamps are wired to the reed relays via 1k resistors in the air to minimize leakage
All of the input circuit from the bnc's to the non invering inupts of the opamps are wired off board to minimize leakage
I know how to offset the input cable capacitance by using a guard opamp
the plan was to be able measure the impedance from 1m ohm to 100M ohm driven by 1vrms sine wave 100Hz to 100Khz
I could not fine much information on the internet on how to neutralize the input capacitance for a non inverting opamp buffer
impedance measurement up to 100K ohm ok
thanks
john
thanks
john
