Hi, I am doing a target mat project for tennis and my problem isn't to do with the circuit but it is to ask what you guys think is the best way to manage the cables as I have total of 5 LED rows and so I have a positive and negative on each. Therefore, I have a total of 10 cables running to the LEDs and I want the LED block to be removable from the circuit board so I was thinking of using a 10 way inline connector such as this: http://uk.farnell.com/jsp/displayPr...ce=true&mckv=YKMwxwd8|pcrid|14164337469|plid|{placement}
However, I am not sure as to whether this is the best way to do it. What other ideas do I have?
I also will need a 6 way connector for the mat end as there will be 5 areas of the mat, as well as the common and so a total of 6 wires are running to the mat.
