Hi, I need help by someone who is very knowledgeable with infrared sensors / detectors etc. I have bought a sleep mask that can detect when a person is in REM sleep (dreaming) The sleep mask has a small circuit board inside with an infrared detector that detects eye movementthroughout the night.
When the infrared detector picks up a lot of eyeball movement it then knows the person is dreaming and will flash 2 bright LED lights at the closed eyes allowing the dreamer to know when they are dreaming. The device is acurate and does what it says 'on the tin' Anyway, my issues are as follows. I am concerned that all night i have a electronic sensor constantly monitoring my eye for movement.
The reason this is a concern is that it could damage the eye / long term problems etc. Im no expert but having infrared detector / device 1mm from the eye all night could be dangerous?
This is a passage from their website ........... "The REM-Dreamer uses infrared sensors to detect when you are in REM (dreaming) sleep. At that point the REM-Dreamer gives you sound and light cues (beeps and flashing lights) to remind you that you are dreaming. Thus, external world stimuli are transferred to the world of your dreams, and it becomes easy to achieve lucidity"
Please take a look at their website to get full details on this device, thanks you
RemDreamer description - http://remdreamer.com/index.php
Rem dreamer photos - http://remdreamer.com/rem-dreamer_pro.php Thank you Terry
