I've built the circuit shown at the following link:
http://www.mitedu.freeserve.co.uk/Circuits/Interface/irext5.htm
However, I seem to be having a problem regarding ambient light. I did
make one change to the circuit. Since I couldn't find the SFH2030 IR
detector diode, I used a Vishay BPV22NF with a daylight filter. Also,
it might be worth noting that I used a wall wart to power the device
instead of a battery. Anyway, the only way I can get the device to
work is to completely turn all of the lights off in the room. Is there
some way to get this to operate so that the circuit is insensitive to
ambient light such as daylight and 60 Hz lighting? I'm new to IR
circuits, but I'm guessing that this has something to do with the
reverse bias levels on the IR detector diode, but I'm not sure. Any
help would be appreciated.
The reason I select this circuit was because I thought it was less
prone to the effects of ambient light.
