Mark
I am relatively new to Infra-Red Electronics and I need help please. I
need to "see" how fast an Aluminum Bar (unpainted/unpolished) passes
in front of a panel. The bar is about 25mm (1") in diameter and it can
pass in front of the panel at different distances from it, ranging
from 0 to about 250mm (10"). I need to do this with a row of Photo
transistors (I cant use Ultrasonic's in this application) and a
Microprocessor using the 10 bit ADC feature. My initial thoughts were
to mount the photo transistors in parallel mounted Black tubes,
pointing towards the target area, so that they had a limited viewing
angle, flood the area in front of the panel with Infra Red light, see
the reflection, let the Microprocessor decide if it is a valid
reflection or not, and then calculate the speed in the usual way. The
panel will be in daylight, but not pointing directly at any bright
light source. Cost is an issue. so this precludes me from using very
expensive devices.
I would welcome any advice people can give me, like is what I am
suggesting feasible? what size LED's/Photo-Transistors to use
(3mm/5mm), what wavelength of Infra-red light would yield the best
results, what would be a good starting length for the Black Tubes,
recommendations of which device's to use, is it worth flashing the
Infra-Red light source, to help with ignoring the ambient light
problem, would I need to amplify the output of the photo transistor or
will a simple resistor up to 5v be good enough with a 10 bit DAC.
Sorry for so many questions, but as I say, I have not done much work
with Infra-Red before.
Thanking you in anticipation
Mark in Spain
[email protected] (remove the X to reply)
expensive devices.
Mark in Spain
