I have some infared securtiy lights (PIR) that detect motion, but gradually 2 or 3 of them have started to just stay on when I turn the switch on,
Anyone got any experiennce of this?
...Initially you need to open them up and check for spiders etc etc inside the units
they drive PIR's crazy.
...check that the PIR's are clean from dust etc.
...check the operation of the PIR cct it probably have a relay output, see if you can determine if its triggering. maybe its stuck in the triggered mode either cuz its failed or it has voltage across the coil all the time determine which one of those
...determine if moisture has got into the system and corrosion is possibly shorting out the cct and causing false operation.
...check the sensitivity adj trimpot and see if it has any effect on operation
those are a few things to check
