Oh, that's a horse of a different color.
Are you intent on getting information / data across the divide or
power, or both?
Say you had a 4-20 ma industrial control sensor that had to transmit
info to the other side of a sealed glass block. You might put a cup
core on both sides of the glass, excite the one outside the glass with
a square wave. It's opposite number is on the inside of the chamber
and connected to a sensor. The 4-20 sensor is connected to the full
wave rectified and filtered cup core coil on it's side of the glass.
As long as the gap remains constant that might be all you'd need . . .
measure the current used by the square wave driver and massage it to
replicate the 4-20.
You mention a voltage level. Power across the divide . . . That is
usually done using two halves of a ferrite cup-core and a high
frequency drive square wave. The distance is critical to both the
voltage and current in that scheme so if the distance will vary the
power transfer efficiency will vary too.
Basically just a transformer with a gap in the magnetic circuit.
Bigger cores work better over larger gaps.
They use something like that on a prototype electric car - the coil
with pole pieces is excited at a high frequency and slipped into an
opening in the body of the vehicle that contains a pair of cup cores
with windings that pick up the AC signal and use it to charge the
batteries (a consumer safe way to transmit power in any environmental
condition)
