Rob Lucas
I've just discovered that the previous owner of my house installed a
15 amp circuit feeding the detached garage by burying a standard 14
gauge flexible-metal-conduit cable about 6 inches under the lawn. This
is the stuff that has the two plastic coated conductors and an
unshielded ground wrapped in a continous coil of glavanzied steel (or
is it aluminum?).
Anyway, how many years can I expect before this installation causes me
problems? I figure worst case in 20 or 30 years the shielding and
ground wire will have rotted away, but the first thing the cable does
in the garage is go through a GFI outlet, so realistically it should
still be safe even without the ground. How long before the standard
plastic coating on the hot wire is deteriorated by the soil? (assuming
someone doens't put a garden shovel through it first!)
I really dont want to dig this whole thing and replace it. Cheers.
is it aluminum?).
