K
Klaus Kragelund
Hi
I have an application where I have a quad LM324 opamp and I'm using
only three of the opamps in the package. I would like to use the last
opamp as a comparator.
For simplicity the opamp is supplied from 5V and the value I compare to
is 2.5V. The input is fed directly to the other input. My problem is
though that the opamp saturates against either rail and is slow when it
needs to change the output state. (input stage i saturated due to V+/v-
is not operating closed loop
Are there a fancy way to actively clamp the output just below either
rail to speed up the "out of saturation" time?
Regards
Klaus
Regards
Klaus
