Platforms
Content
electrolytic capacitor 47 microF 60VWhat sort of capacitors are you using? Some can vary in capacitance with voltage.
Place a small capacitor across the motor and another one across the pins of the 555.
I suspect that noise from the motor is affecting the detection of the upper and/or lower thresholds. Changing the battery voltage may also change the impedance of your supply leading to more or less effect from the motor.
ok i will try and let you knowTwo, one across the motor, one across the power supply pins of the 555
I see a puny 9V battery in your video. With that in mind I don't understand any of this quote.one more thing, output of 555 timer without coin vibrating motor is 3.5v for 5v supply. but when i connect motor it reduces to 2.5v and causes less vibration. can i know why and how to overcome? i even tried using amplifier. also i tried using arduino with code(blinking led), without motor it was 5v with motor it was 3.5v
i just referred that video and designed it for 5vI see a puny 9V battery in your video. With that in mind I don't understand any of this quote.
Chris
