Hello
I have a small LED piano lamp which has a 5v dc input and a self locking switch (I think). There is a small pcb of which the mains lead pugs in to (assuming this is the power supply module) which also connects the battery leads to the LED circuit. I think that this pcb/power supply module is faulty however struggling to find a replacement. Everything I have found starts at a higher voltage e.g. 6.5-12v and has an output of 5v but I already have 5v dc at the power lead. Don't want to just bypass this module as assuming it protects the LEDs. Can anyone suggest where I might find a replacement, what it would be called and/or how I can fix this. The switch is a separate unit at the moment, linked with two leads inside the lamp base unit. The lamp is a stagg STLED 10.
Many thanks,
Ben
Many thanks,
Ben
